I made some changes to revsion cheme and after that i got this error:
How do I get them working again? Here are the old and new settings:
old one:
new one:
And here you can see that for example the part J5L00135 doesnt want to use "koe" status.
And here are the settings for lifecycles if it helps:
What would be the best way to get these parts into new revision scheme?
you changed the separator, secondary and working copy.
that's quite a bit. those are "significant" changes.
A-01 is not equal to A01
A-01 is not equal to A1
01 is not equal to 1
any one of those will cause WPDM to reset back to first rev on next checkin of existing documents.
new documents will not be affected.
examples
if A-01 is in vault then upon checkin the "next logical revision" will be -, -1 or -+
because the revision scheme was changed, wpdm will reset back to first revision in table.
optionally you can manually type in A2 or B
for lifecycle issue
