Hi
I am trying to figure out what flow simulations do when the High Mach number flow option is enable.
I found some documents (see attached file) about the matter in technical reference, basically saying that the energy equation to be solved is rearranged when the High Mach number flow option is enable. Does anyone know what is the reason of solving the rearranged the energy equation?
Do you have a problem with a know solution that isn't solving properly?
One thing about flow is that the developers have spent a lot of time to ensure the interface makes it easy to setup the problems and output good, accurate results . They've also documented much of it but sometimes it isn't exactly obvious to non developers on the reason why they used a certain solving method. Concentrating on the solutions to start may help yoga newer your question. Or dig into the References of the references.
