Our document control department would like us to put the drawing number, revision and job number variables onto our drawing but displayed as a barcode.
Has anyone done this and if so, how? Thanks!
Denny
Denny
Greg Rupp wrote:
Hello Denny, All you need to do is download a Barcode Font. I believe there are several free ones available on-line. Then, on your title block, put a text field with your info in that barcode font.
Good luck,
Greg
but there are many different barcode font ,such as code 39 font ,code 128 font,ean font ,etc how to choose ?
It will depend on your application.
Most bar code scanners/software will read a large variety of code types, but that might also be a factor.
My suggestion... Use Code 128. It has a lot of flexiblity, allowing you to barcode practically anything at any length.
If you get creative with your barcodes, it can contain a large amount of information. If you do that though, be aware of the length/size of the barcode.
basically we have these variables that I need already populated on our existing title block. Can I just use the same variable and put it in two places with one of the instances being a barcode font or should i have a new variable just for the barcode?
Variables being barcoded
Job Number (this is five digits but could potentially have a dash like 12345-1)
Drawing Number (this varies but could be D-12345-0200 50)
Revision (this is usually a single character A thru F or 0 thru 9)
Good luck,
Greg
