6 Replies Latest reply on Jan 30, 2014 9:06 AM by Yosi Shani
    VBA CODE TO INSERT DesignTable TO DRAWING
    Yosi Shani
      Hey all
      Is their a way to insert DesignTable to drawing (opened drawing) with macro?
      I managed to insert BOM table and revision table with macro but not DesignTable.
      I will appreciate any help
      Yosi
        • Re: VBA CODE TO INSERT DesignTable TO DRAWING
          Artem Taturevych
          You cannot create Design Table in Drawing (same behaviour from User Interface). You can only propagate the Design Table from underlying part or assembly to drawing. Make sure that you selected the drawing view which is referencing the part or assembly with design table. Then call this method: ModelDoc2::InsertFamilyTableNew.
          Please read the remarks session here: http://help.solidworks.com/2014/English/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.imodeldoc2~insertfamilytablenew.html
              Yosi Shani
              Hi Artem
              I tried to use InsertFamilyTableNew. but got a message box about variable.
              I have a code that opens from drawing the design table (from part). I run this code when drawing is open
              what do I miss in my code to insert the design table in the drawing. can I insert the design table in a spesific point in drawing?
              attaching the part and drawing files I'm testing
              here is the code:
              Option Explicit
                    Dim swApp                 As SldWorks.SldWorks
                    Dim swModel               As SldWorks.ModelDoc
                    Dim swDesTable            As SldWorks.DesignTable
                    Dim nErrors               As Long
                    Dim nWarnings             As Long
                    Dim longstatus            As Long
                    Dim myView                As SldWorks.View
                    Dim designTableDoc        As SldWorks.ModelDoc2
                    Dim viewModelName         As String
                    Dim myDesignTable         As SldWorks.DesignTable
                    Set swModel = swApp.ActiveDoc
                    Set myView = swModel.GetFirstView
                    viewModelName = myView.GetReferencedModelName()
                    Set designTableDoc = swApp.ActivateDoc2(viewModelName, True, longstatus)
                    Set myDesignTable = designTableDoc.GetDesignTable()
                    Set myDesignTable1 = designTableDoc.InsertFamilyTableNew(myDesignTable)
                    myDesignTable.Attach
                  Simon Turner
                  Option Explicit
                  Option Compare Text
                  Dim myDoc As ModelDoc2
                  Dim boolstatus As Boolean
                      Dim myView As View
                      Dim myDraw As DrawingDoc
                      Dim myName As String
                      Set myDoc = swApp.ActiveDoc
                      Set myDraw = myDoc
                      Set myView = myDraw.GetFirstView
                      Set myView = myView.GetNextView 'Because the first view is the drawing sheet
                      If myView Is Nothing Then Exit Sub
                      myName = myView.Name
                      boolstatus = myDoc.ActivateView(myName)
                      boolstatus = myDoc.Extension.SelectByID2(myName, "DRAWINGVIEW", 0#, 0#, 0#, False, 0, Nothing, 0)
                      myDoc.InsertFamilyTableNew
                      Yosi Shani
                      Hi Simon
                      Thank you very much. it works great
                      can I insert the design table in a spesific point in drawing? (for example in the right corner)
                      Yosi
                          Simon Turner
                          You can alter the Boundary of the OLEObject:
                          Option Explicit
                          Option Compare Text
                              Dim myView As View
                              Set myDraw = myDoc
                              RepositionLastOLEObject
                          Sub RepositionLastOLEObject()
                              Dim myObj As SwOLEObject
                              Dim myBoundaries As Variant
                              Dim myOLEobjs As Variant
                              Dim myHeight As Double
                              Dim myWidth As Double
                              Dim x As Double
                              Dim y As Double
                              myOLEobjs = myDoc.Extension.GetOLEObjects(swOleObjectOptions_e.swOleObjectOptions_GetAll)
                              If IsEmpty(myOLEobjs) Then Exit Sub
                              Set myObj = myOLEobjs(UBound(myOLEobjs))
                              myBoundaries = myObj.Boundaries
                              'Existing height & width
                              myHeight = myBoundaries(4) - myBoundaries(1)
                              myWidth = myBoundaries(3) - myBoundaries(0)
                              'New position
                              x = 250 / 1000
                              y = 500 / 1000
                              myBoundaries(0) = x
                              myBoundaries(1) = y
                              myBoundaries(3) = x + myWidth
                              myBoundaries(4) = y + myHeight
                              myObj.Boundaries = myBoundaries
