7 Replies Latest reply on Jan 30, 2014 4:58 PM by Seth Ruhan
    Retrieving Weldment Custom Properties
    Chris Day
      I'm trying to get the code linked below to work on a multi-body part with structural members and plates. When I select the Structural Member feature in the FeatureManager Tree and run the code swSelMgr.GetSelectedObject6(1, 0) returns null. The code therefore fails at For Each name In names as names is empty.
      Get Custom Properties for Weldment Cut-list Item Example (VBA)
      Although I'm running 2013 SP5 the GetSelectedObject6 method does exist, so I'm not sure what else could be at fault.
        • Re: Retrieving Weldment Custom Properties
          Artem Taturevych
          The expected feature is not a weldment feature but the cut-list feature under the cut-list folders.
          GetSelectedObject6 method is available from SolidWorks 2006. I assume it just doesn't list in your intellisense (happens to me sometimes in SolidWorks 2013 and 2014 with new VB7 engine).
            Seth Ruhan
            All though you have your solution, Here's some thing from the libary
            1 - Update Cut lists (inc Sheet metal bouding box's)
              2 - Get Cut List Items as OO
            3 - Cut List Class, Inc Custom Properties & Type of item
            Update Cutlist (inc Sheet metal bounding box) wrote:
            Public Function RebuildCutListFeature(ByVal ModDoc As ModelDoc2) As Boolean
                    Try
                        If ModDoc.GetType <> swDocumentTypes_e.swDocPART Then Return False
                        Dim swPart As PartDoc = ModDoc
                        Dim BodyFolder As IBodyFolder = Nothing
                        If Not swPart.IsWeldment Then
                            Return False
                        'Update Bouding Box
                        Dim swFeat As Feature = swPart.FirstFeature
                        Do While Not swFeat Is Nothing
                            If "FlatPattern" = swFeat.GetTypeName2 Then
                                swPart.ClearSelection2(True)
                                swFeat.Select2(False, -1)
                                If swPart.EditUnsuppress2 Then
                                    swPart.ForceRebuild3(True)
                                    swPart.EditSuppress()
                            swFeat = swFeat.GetNextFeature
                        Loop
                        'Update Cut list items
                        swFeat = swPart.FirstFeature
                            If "SolidBodyFolder" = swFeat.GetTypeName2 Then
                                BodyFolder = swFeat.GetSpecificFeature2
                                If BodyFolder.GetAutomaticCutList Then
                                    BodyFolder.UpdateCutList()
                        Loop
                        Return True
                    Catch
                        Return False
                    End Try
                End Function
            Get Cut list properties (OO) & Cut list class:
            Public Function GetCutListItems() As List(Of CutListItem)
                    If _AllCutListFeats Is Nothing Then
                          Dim aFeature As IFeature = ModDocExt.ModDoc.FirstFeature()
                        Dim CutListFeatures As New List(Of CutListItem)
                        Do While aFeature IsNot Nothing
                            If aFeature.GetTypeName2 = "CutListFolder" Then
                                Dim CutFolder As BodyFolder = aFeature.GetSpecificFeature2
                                If CutFolder.GetBodyCount > 0 Then
                                    CutListFeatures.Add(New CutListItem(aFeature))
                            aFeature = aFeature.GetNextFeature()
                        Loop
                        If CutListFeatures.Count = 0 Then
                            Return Nothing
                        Else
                            _AllCutListFeats = CutListFeatures
                    Return _AllCutListFeats
                End Function
            Public Class CutListItem
                Public Feature As IFeature
                Dim CustPropMgr As CustomPropertyManager
                Public Sub New(ByVal Item As IFeature)
                    If Item.GetTypeName2 = "CutListFolder" Then
                        Feature = Item
                        CustPropMgr = Feature.CustomPropertyManager
                Public Function CustomProperties() As List(Of CutlistProperty)
                    Dim swCustPropMgr As CustomPropertyManager = Feature.CustomPropertyManager()
                    If swCustPropMgr.Count > 0 Then
                        Dim Props As New List(Of CutlistProperty)
                        For Each name As String In swCustPropMgr.GetNames
                            Props.Add(New CutlistProperty(Me, name))
                        Next
                        Return Props
                    Return Nothing
                End Function
                Function DeleteProperty(ByVal Value As String) As Boolean
                    Return CustPropMgr.Delete(Value)
                End Function
                Function DeleteAllProperties() As Boolean
                    For Each name As String In CustPropMgr.GetNames
                        CustPropMgr.Delete(name)
                    Next
                    Return True
                End Function
                Public Property CustomProperty(ByVal Name As String) As String
                    Get
                        Try
                            Dim ValueOut As String = ""
                            Dim ResovedValue As String = ""
                            CustPropMgr.Get2(Name, ValueOut, ResovedValue)
                            Return ValueOut
                        Catch
                            Return Nothing
                        End Try
                    End Get
                    Set(ByVal value As String)
                        If CustomProperty(Name) <> "" Then
                            CustPropMgr.Set(Name, value)
                        Else
                            CustPropMgr.Add2(Name, swCustomInfoType_e.swCustomInfoText, value)
                    End Set
                End Property
                Public ReadOnly Property ResovedValueCustomProperty(ByVal Name As String) As String
                    Get
                        Try
                            Return ResovedValue
                        Catch
                            Return Nothing
                        End Try
                    End Get
                End Property
                Public ReadOnly Property Type() As CutListType_e
                    Get
                        Try
                            Dim CutFolder As BodyFolder = Feature.GetSpecificFeature2
                            Dim ABody As Body2 = CutFolder.GetBodies(0)
                            For Each Feat As Feature In ABody.GetFeatures()
                                Dim FeatType As String = Feat.GetTypeName2
                                If FeatType = "SMBaseFlange" Or _
                                   FeatType = "SheetMetal" Or _
                                   FeatType = "SM3dBend" Or _
                                   FeatType = "SMMiteredFlange" Or _
                                   FeatType = "ProcessBends" Or _
                                   FeatType = "FlattenBends" Or _
                                   FeatType = "EdgeFlange" Or _
                                   FeatType = "FlatPattern" Or _
                                   FeatType = "Hem" Or _
                                   FeatType = "Jog" Or _
                                   FeatType = "Rip" Or _
                                   FeatType = "CornerFeat" Or _
                                   FeatType = "LoftedBend" _
                                    Then
                                    Return CutListType_e.SheetMetal
                                ElseIf FeatType = "WeldMemberFeat" Then
                                    Return CutListType_e.StructuralMember
                            Next
                        Catch ex As Exception
                            Return CutListType_e.Unknown
                        End Try
                    End Get
                End Property
                Enum CutListType_e
                    Unknown
                    StructuralMember
                    SheetMetal
                End Enum
            End Class
