Hi All
I normally use the arrow keys to rotate the views in SW. I found Ctrl-Z was too close to Ctrl-S and it was annoying to hit Ctrl-Z by mistake when I intendewd to hit Ctrl-S (to save my work). Because then I had to re-do again and SW does not have a successful Re-Do. So I decided to re-assign Ctrl-Z to something like Ctrl-Q. But suddenly now my left key does not work any longer. What could have happened? Very frustrating.
I would rest back to default. Control_Q is a system assigned key for full rebuild, don't over write to something else!!!!!
Have you shut down and restart your SW? if you have and the arrow button no long rotates the model reset to default.
you know you can hold down the wheel on your mouse to rotate your model??
