Hi, I've been watching YouTube again and wonder if there is a way to mimic the process of oval turning ( http://www.youtube.com/watch?v=cDq5oHVD294 )
The basic process being as follows:
Two pieces of the desired wood with a sacrificial piece of wood in the centre,
A revolved cut around the assembly,
Remove the sacrificial piece of wood from the centre,
Mate the two pieces of desired wood together (and possibly a final revolve cut on the stem)...
The basic assembly, revolved cut, and removal of the sacrificial piece, all work fine. The problem occurs when I try to mate the two desired pieces together...
How ever I try to mate the two desired pieces together, the revolved cut then does not work. I.E. the desired pieces pull together and the cut updates to that shape - thus not achieving the effect I am after
I believe what is happening is that the order places the rearrangement of the components before the revolved cut... I cannot re order this.
I know that I could do the parts separately and then do a final assembly, once they are all fully shaped... but I would like to replicate the process if at all possible.
Thanks for reading.
I've attached a basic model - I figured that I'd start small and see if it can work before I make anything pretty
Create it as a multi-body part. After the revolved cut, delete the center body, then use the move/copy body command. See if that doesn't get you the result you want.
