I am working on the SolidWorks tutorial for the nozzle located in basic techniques/surfacing. After creating the base, handle and nozzle I use the split lines tool to divide the nozzle and base and then create two lofted surfaces to connect the parts. The next step is to knit the surfaces but when I do this I get the following message: There are no edges to knit. Please loosen the knitting tolerance according to the gaps.
The base file is from SolidWorks so this should work but it does not. Does anyone have experience with this file? I need to get through the knit step so that I can proceed with creating the filled surfaces.
Attach the *.sldprt file here finished up to the step where you are seeing this behavior.
(click on Advanced - upper right corner when replying, or edit your previous post and in lower left corner click Browse in the Attach.)
