IM DOING SOMETHING NEW AND IM HAVING DIFFICULITIES TRYING TO MAKE IT HAPPEN IN SHEET METAL. I HAVE A FORMED SIDE PIECE THAT BENT IN SEVERAL PLACES, I NEED TO ROLL AT 360 DEGREE ON A 66" DIAMETER, IM NOT SURE WHERE TO EVEN BEGIN... ANY HELP IN THIS DIRECTION WOULD BE HELPFUL
SO FAR I CAN GET IT TO REVOLVE BUT THAT DOESNT CREATE THE EFFECT I WANT.
IF ANYONE KNOWS WHAT ROLLED ANGLE IS THAT'S BASICALLY WHAT IM TRYING TO DO
if I understood.... instead a revolve, you can create a polygon with the diameter you need, use surface extrude, thicken and then convert to sheet metal... it could be easier ways to do it, but that is the way I do it in limited knowledge...
