Is there a way to move the constraint icons? When I am sketching, the constraint icons are directly over points and vertices. This makes it difficult to select points instead of lines unless you use the select other option. I may be wrong but I don't think I had this issue in 2013.
Jason
Solidworks 2014 sp1
Try unchecking "Sketch Relations" on the View menu.
