Greetings,
when we export our solidworks drawing to .dwg format, solidworks creates a dimstyle. Is there any way to adjust the settings in those dimstyle before exporting?
In our solidworks drawing we are using "Feet and inches" rounded to 1/16", once exported the dimstyle is "Fractionnal" rounded to 1/8" plus the alternate unit scale factor is 304.8 instead of 25.4 as if the unit was in feet instead of inches. The dimension shows up the same way as the original solidwork drawing until we do any command to it (move, copy, etc.)
Using SW 2013 SP 2.0
Also, Solidworks create multiple dimstyles instead of grouping all dimensions under the same one. Is there a way to prevent that?
