0 Replies Latest reply on Jan 16, 2014 12:06 AM by Feng Wei
    Bug in motion study2
    Feng Wei
      I create this topic because I can't reply with attachment in last similar topic.
      I input the 2704 point positions at the time scale of 5ms, do the motion study and output the plot results of the original point. However, the output data only has 339 lines. I compare the two files, only to find the result file jump every nine lines and the data is a little different from original data. What happened?
      Pls See attached files.
      Trajectories.xlsx is the experiment data.
      Sheet_**.csv files are processed displacement by myself to drive the motion.
      Trace Path1.csv is the result of "trace path" function in motionstudy from your powerful software...
      you could see this result is extremely different from its original experiment data "Trajectories.xlsx ".
      Would someone in your develop program leave this bug intentionally? Thanks.
