Hi There,
I have a Master Assembly (Huge) with many Sub Assemblies. Many times a few parts are added onto the main Assembly, So now I have a Bunch of Sub-Assemblies and Mated Parts in the Master Assembly.
Is it Possible to Highlight Components and Merge/Combine Them into an Existing SubAssembly OR Highlight Parts that I want as a SubAssembly and Convert Them into a Seperate Sub Assembly Whithout Having to Create New Sub-Assemblies and Remate Everything together.
I Have the 2014 Version of SolidWorks.
Thank You Guys For Reading
As Always All the Help is Appreciated
you can drag parts in the tree into the sub-assy you want them to join.
you can select a few parts, right click and choose "form new subassembly here"
- note: not all mating schemes will survive either operation, so you may have some clean up to do.
