11 Replies Latest reply on Jan 18, 2014 9:59 AM by Luis Oliveira
    Macro help
    Luis Oliveira
      I am building a Macro to fill my cutom properties list. So far, so good. it already populate the most important fields
      But now I want to upgrade it. In order to save time, I want the macro to see if the part is a sheet metal part and if yes, add the thickness and other properties to that list
      If anyone can help me I would apreciate..
      Thank you
        • Re: Macro help
          Artem Taturevych
          Hello Luis,
          Try this: PartDoc::GetBodies2->Body2::IsSheetMetal
            • Re: Macro help
              Luis Oliveira
              Sorry, I didn´t understand. I'm programming in VBA. I didn't follow your thought. Can you explain a little better?
                • Re: Macro help
                  Christian Chu
                  There is an add-in called "Property Tab Builder" included with your SW
                  You can use this addin to customize the SW properties - it's nice features and what I mean here is you don't need to write your own macro for this task - there is one available for you to use
                  Chris
                  • Re: Macro help
                    Artem Taturevych
                    You can call PartDoc::GetBodies2 to get an array of bodies from your part. Then you can call Body2::IsSheetMetal for each body to identify whether it is sheet-metal body or not.
                      • Re: Macro help
                        Luis Oliveira
                        I've been trying to use those but it's still wrong. could you see were I miss?
                            Dim swModel As ModelDoc2
                            Dim swPart As IPartDoc
                            Dim Bodies As Object
                            Dim Body As IBody2
                            Dim Sheet_metal As Boolean
                            Dim BodyType As Integer
                            Dim BVisibleOnly As Boolean
                            Set swModel = swApp.ActiveDoc
                            Set swPart = Ctype(swModel, PartDoc)
                            Bodies = swPart.GetBodies2(swBodyType_e.swAllBodies, False)
                            Body = Bodies(1)
                            Sheet_metal = Body.IsSheetMetal()
                            If Sheet_metal = True Then
                            swModel.AddCustomInfo2 "QUANTIDADE", swCustomInfoText, InputBox("QUANTIDADE")
                          • Re: Macro help
                            Artem Taturevych
                            Dim Bodies As Variant
                            Dim swBody As IBody2
                            Set swBody = Bodies(0)
                            Sheet_metal = swBody.IsSheetMetal()
                              • Re: Macro help
                                Luis Oliveira
                                now I have this message: sub or function not defined. I think its the Ctype...
                                  • Re: Macro help
                                    Artem Taturevych
                                    CType is VB.NET function not VBA:
                                    Set swPart = swModel
                                      • Re: Macro help
                                        Luis Oliveira
                                        this is funny. I probably am doing a very basic error but I don't know where. look at the code:
                                            Bodies = swPart.GetBodies2(swBodyType_e.swAllBodies, True)
                                            swModel.AddCustomInfo2 "A", swCustomInfoText, Sheet_metal
                                            swModel.AddCustomInfo2 "B", swCustomInfoText, InputBox("B")
                                            ElseIf Sheet_metal = False Then
                                            swModel.AddCustomInfo2 "C", swCustomInfoText, InputBox("C")
                                        the result: it adds a custom property named A with True or False. All good until now, but then nothing happens. Do you know why?
                                          • Re: Macro help
                                            Simon Turner
                                            Never test whether a Boolean = True.
                                            In VBA, False equals zero, but any other number is considered to be True. So testing whether 2 Booleans variables are equal to one another could be equivalent to asking if -1=1.
                                            It is safe to ask if a Boolean <> False
                                            Also, you are using AddCustomInfo. If the part already has a custom property, then AddCustomInfo doesn't work. You need to test if the variable already exists. If so, you need to set it rather than try to add it again.
