I have a 7 item drawing bom but the model cut-list has only 6 items under it. Items 3 & 7 are the same but with a hole at 90deg difference. The problem is I can't edit the properties.
This is part of what is a very common occourance in weldments. You have 7 items because the cutlist is referencing the "As Welded" Derived configuration. In that you have 7 parts on your cutlist.
I usually delete that configuration as soon as I start a new weldment to avoid that problem.
