Hi all,
I have the solidworks composer just a fiew days now and training will be end of March (way to long). So I am glad that this forum exists.
I received an .smg file from our engineer to work with in the solidworks composer. Unfortunately the file is delivered with the solidworks logo and our engineer does not know how to get rid of it. So is there a way to get rid of if within Solidworks Composer?
If someone knows how to get rid of it in Solidworks he is most welcomed to answer here also.
Thank you Astrid.
If you want to use the ground, you can go into the Viewport category on the Document Properties dialog. There you will remove the %DS% from the Texture path field. Alternatively, you could put your own logo to have that on the ground.
-Earl
