4 Replies Latest reply on Jan 13, 2014 6:31 AM by Deepak Gupta
    set a new model view in particular angle
    Suresh Kumar Radhakrishnan
      i am trying to set a model in a new orientation so that i can retrieve when i require. If i use space bar and select new named orientation, i unable to set a view which is in some angle with the certain plane. If i want normal to the plane, i have option by selecting a face and click normal to option. But, i selected a particular face first and selected normal to option. Now, the particualr face becomes normal to the screen. My next requirement, by keeping that normality, i need to rotate the model to some angle to other plane so that model to rotate on a particular normal view. If i use the rotate command by view-modify, the model can be rotated without any particular angle setting. Kindly suggest a way.
      Regards,
      Suresh
