1 Reply Latest reply on Jan 11, 2014 1:04 AM by Simon Turner
    Populate array for SolidWorks Components and then use it
    Steve Anderson
      The program errors here: swComp = swCompArr(i) with Rin-time error 91, Object Variable or With block variable not set
          ' Connect to SolidWorks
          ' Assembly, Current active document if it is an assembly
          Set swAssy = swApp.ActiveDoc
          Dim i As Integer
          i = 0
          Dim c As Integer
          c = swAssy.GetComponentCount(True)
          MsgBox c
          Dim swCompArr As Variant
          swCompArr = swAssy.GetComponents(True)
          Do While Not i = c
              If Not IsEmpty(swCompArr) Then
                  ' Component Part No must begin with 242 and not be supressed
                  If swComp.IsSuppressed = 1 Or Left(swComp.Name, 3) <> "242" Then
                      ' Do Nothing
                  Else
                      ' Set Component
                      Dim swModel2 As SldWorks.ModelDoc2
                      swModel2 = swComp.GetModelDoc2
                      Dim swModelDocExt As SldWorks.ModelDocExtension
                      swModelDocExt = swModel2.Extension
                      swSelMgr = swModel2.SelectionManager
                      Dim bComp As Boolean
                      bComp = swModelDocExt.SelectByID2("#20 (0.161) Diameter Hole1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, swSelectOptionDefault)
                      Dim Feature As SldWorks.Feature
                      Feature = swComp.FirstFeature
                      Do While Not Feature Is Nothing
                          If Feature = "#20 (0.161) Diameter Hole1" Then
                              MsgBox "Found " & Feature.Name
                          Feature = Feature.GetNextFeature
                      Loop
                      ' Project points
              i = i + 1
          Loop
