5 Replies Latest reply on Jan 14, 2014 10:27 AM by Simon Turner
    Help: Export drawing to PDF, only certain sheets
    Chris Manger
      I am writing a macro to export all sheets except for one that's called "FLAT" to a PDF file.   I took some sample code from the API help.
      Everything works until I get to creating a new array called "varPrint".   I don't use arrays I suspect I am using that variable incorrectly.
      Option Explicit
          Dim swApp               As SldWorks.SldWorks
          Dim swModel             As SldWorks.ModelDoc2
          Dim swDrawDoc           As SldWorks.DrawingDoc
          Dim swModelDocExt       As SldWorks.ModelDocExtension
          Dim swExportPDFData     As SldWorks.ExportPdfData
          Dim boolstatus          As Boolean
          Dim filename            As String
          Dim lErrors             As Long
          Dim lWarnings           As Long
          Dim strSheetName(4)     As String
          Dim varSheetName        As Variant
          Dim varPrint(2)            As Variant
          Dim i                   As Integer
          Dim count               As Integer
          ' Path to which to save PDF file of drawing
          filename = "C:\test.PDF"
          swApp.Visible = True
          ' Open specified drawing
          Set swModel = swApp.OpenDoc6("C:\test.SLDDRW", swDocDRAWING, swOpenDocOptions_Silent, "", lErrors, lWarnings)
      '    Set swModelDocExt = swModel.Extension
          Set swDrawDoc = swModel
          varSheetName = swDrawDoc.GetSheetNames
          count = swDrawDoc.GetSheetCount
          For i = 0 To count - 1
              If varSheetName(i) <> "FLAT" Then
                  varPrint(i) = varSheetName(i)
              'MsgBox varSheetName(i)
          Next i
          Set swExportPDFData = swApp.GetExportFileData(3)
      '    If swExportPDFData Is Nothing Then MsgBox "Nothing"
          boolstatus = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets, varPrint)
      boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportPDFData, lErrors, lWarnings)
        • Re: Help: Export drawing to PDF, only certain sheets
          Simon Turner
          I haven't tested this, but I have corrected the code:
          Option Explicit
          Option Compare Text
          Dim lErrors             As Long
          Dim strPrint()          As String
          Dim nPrint              As Integer
          Dim varPrint            As Variant
          Dim i                   As Integer
              nPrint = -1
                      nPrint = nPrint + 1
                      Redim Preserve strPrint(nPrint)
                      strPrint(nPrint) = varSheetName(i)
              Next i
              varPrint = strPrint
