Is it possible to get SW to display separate windows on both
monitors? I have a NVIDIA Quadro FX4500 graphics card. The only way
I have been able to get this work is to set display mode to
horizontal span so that SW will display on both monitors as one
window. This is not ideal when working with other programs because
they also will span across both monitors. I have used Pro-E in the
past and it is possible to drag windows between monitors using the
dual view setting on the graphics card. Is this supported by
SW?
Can you post the specs for your computer?
What happens when you try it?
I posted a screen grab to help you navigate the interface.
John
