SW14 SP1 drawing shows wrong dims compared to the actual holes and also instead of the actual text shown, it shows the code used to generate the text in some cases. Output is set to 1:1. Never had problems with SW13 SP3. Any suggestions?
Tom,
They do... But your VAR is your first line of contact for support/bug issues.
Post your model and drawing for us to try. Post screen shots of what you are seeing.
We do not see this with the DWG exports we do. We are on SW2014 SP1.
Do you have the appropriate settings under the Options when you Save As? Specifically the Base Scale (Sheet or Views dropdown)
Cheers,
Anna
Do any Solidworks Corp software techs monitor these posts or is this simply a peer to peer message board?
