1 Reply Latest reply on Jan 9, 2014 3:12 PM by Matt Martens
    Get Sketch Points
    Steve Anderson
      I have an assembly with a back panel and several lighting components.  Ultimately, I am looking to get the sketch points from each lighting component and transfer them to the back panel, producing an end result of where the connection holes will exist in the back panel.
      I am trying very hard, much too hard in fact!!, to pan through the objects and obtain the sketch points.  My only goal in the code below is to see if I can obtain the coordinate locations.  I velieve the symtax is correct, except for the option to get the sketch points.
                      ' Get Sketch Points
                      Dim vSketchPoints As Variant
                      vSketchPoints = swSketch.GetSketchPoints2  - ERRORS HERE WITH Run-time error '91'; Object variable or With block not set.
                      Dim vSketchPoint As Variant
                      Dim swSketchPoints As SldWorks.SketchPoint
                      Dim swSketchPoint As SldWorks.SketchPoint
      The complete code is listed below:
          ' Connect to SolidWorks
          ' Model - Not used yet
          Set swModel = swApp.GetFirstDocument
          ' Assembly, Current active document if it is an assembly
          Set swAssy = swApp.ActiveDoc
          ' Get Components in assembly
          Dim swCompArr As Variant
          Do While Not swModel Is Nothing
              If Not swModel.GetType = swDocumentTypes_e.swDocPART Then
                  ' Do Nothing
              Else
                  swCompArr = swAssy.GetComponents(True)
              For i = 1 To UBound(swCompArr)
                  Set swComp = swCompArr(i)
                  ' Component Part No must begin with 242 and not be supressed
                  If swComp.IsSuppressed = 1 Or Left(swComp.Name, 3) <> "242" Then
                      ' Do Nothing
                  Else
                      ' Set Component
                      Dim swModel2 As SldWorks.ModelDoc2
                      Set swModel2 = swComp.GetModelDoc2
                      Dim swModelDocExt As SldWorks.ModelDocExtension
                      Set swModelDocExt = swModel2.Extension
                      Set swSelMgr = swModel2.SelectionManager
                      Dim bComp As Boolean
                      bComp = swModelDocExt.SelectByID2("#20 (0.161) Diameter Hole1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, swSelectOptionDefault)
                      Dim Feature As SldWorks.Feature
                      Set Feature = swSelMgr.GetSelectedObject5(1)
                      swModel2.ClearSelection2 True
                      Dim FeatureData As SldWorks.WizardHoleFeatureData2
                      Set FeatureData = Feature.GetDefinition
                      Dim nCount As Long
                      nCount = FeatureData.GetSketchPointCount
                      MsgBox ("Component: " & swComp.Name & " Sketch Point Count = " & nCount)
                      Dim swSketchMgr As SldWorks.SketchManager
                      Set swSketchMgr = swModel2.SketchManager
                      Dim bSketch As Boolean
                      bSketch = swModel2.Extension.SelectByID2("#20_MASTER_Sketch", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
                      Dim swSketch As SldWorks.Sketch
                      Set swSketch = swModel2.GetActiveSketch2
                      ' Get Sketch Points
                      swSketchMgr.InsertSketch False
                      If (Not IsEmpty(vSketchPoints)) Then
                          For Each vSketchPoint In vSketchPoints
                              Set swSketchPoint = vSketchPoint
                              Dim dPoint(2) As Double
                              dPoint(0) = swSketchPoint.X
                              dPoint(1) = swSketchPoint.Y
                              dPoint(2) = swSketchPoint.Z
                              swSketchPoint.Select4 False, Nothing
                              MsgBox dPoint(0) & "; " & dPoint(1) & "; " & dPoint(2)
                          Next
                      ' Project points
              Next
              Set swModel = swModel.GetNext
          Loop
      Any help with this is greatly apprectated.
        • Re: Get Sketch Points
          Matt Martens
          From the remarks section of the GetActiveSketch2 section of the API help:  Before you can use this method, you must select and activate a sketch. You can use IModelDocExtension::SelectByID2 to select a sketch and ISketchManager::InsertSketch to make the sketch active.
                          swModel2.InsertSketch
                          ' Get Sketch Points
          You selected the sketch in the feature tree but you never activated it. So when you used GetActiveSketch2, your swSketch was coming back empty which in turn caused your error the next time you tried to use the swSketch object.
