1 Reply Latest reply on Jan 9, 2014 8:44 AM by Christoph Neundorf
    Open and save the part's journal from a drawing via C#
    Christoph Neundorf
      Hi all,
      i'd like to open the journal file of  part from a drawing using C#.
      Unfortunately the bool swViewStatus (SelectByID2) doesn't get true yet.
                  SolidWorks.Interop.sldworks.View swView = default(SolidWorks.Interop.sldworks.View);
                  swView = ActiveDrawing.GetFirstView();
                  swView = swView.GetNextView();
                  ModelDoc2 swModel = null;
                  int nDocType = 0;
                  if (swView != null)
                      String strModelName = swView.GetReferencedModelName();
                      strModelName = strModelName.ToLower();
                      if (strModelName.Contains(".sldprt"))
                          nDocType = 1;
                          swModel = swApp.OpenDoc(strModelName, nDocType);
                          //swModel = swApp.OpenDoc6(strModelName, nDocType, (int)swOpenDocOptions_e.swOpenDocOptions_DontLoadHiddenComponents, "", 0, 0);
                      else
                          nDocType = 2;
                      if (swModel != null)
                       bool mViewStatus = swModel.Extension.SelectByID2("Journal.doc", "JOURNAL", 0, 0, 0, false, 0, null, 0);
                      if (mViewStatus != true)
                          mViewStatus = swModel.Extension.SelectByID2("Journal.doc (Leer)", "JOURNAL", 0, 0, 0, false, 0, null, 0);
                      if (mViewStatus)
                          MessageBox.Show("Journal selected successfully");
                      swModel.Save3(1, 1, 1);
      Any thoughts?
      Chris
        • Re: Open and save the part's journal from a drawing via C#
          Christoph Neundorf
          This code seems to work.
          swApp.ActivateDoc2(strModelName, false, 0);
          ModelDoc2 swDoc = ((ModelDoc2)(swApp.ActiveDoc));
          object[] oOleObjs = (object[])swDoc.Extension.GetOLEObjects(0);
          foreach (SwOLEObject oOLEObj in oOleObjs)
              if (oOLEObj != null)
                   Word.Document oDoc = (Word.Document)oOLEObj.SetActive(true);
                   oDoc.Application.Visible = true;
                   oDoc.Application.Documents.Add();
                   oDoc.SaveAs2(@"D:\journal.pdf", 17, 0);
                   oDoc = oOLEObj.SetActive(false);
          But how can i check if the OLE object really is the design journal?
          Additionally there seem to be a bug (SPR #386112) so that the OLE document is not opened correctly.
