0 Replies Latest reply on Jan 7, 2014 7:32 AM by Sanjay Phadke
    determine line belongs to block
    Sanjay Phadke
      Hello All
      In  a drawing sketch there are many block & lines
      If user selects a line then I want to capture event that whether that line belongs to sketchblock or it is just a line
      Kindly guide me for the same
      my code is as below
      If swselmgr.GetSelectedObjectType(1) = 10 Then
             Set selLineInst = swselmgr.GetSelectedObject6(1, -1)
            'Debug.Print selLineInst.Layer
            If  selLineInst.Layer = "FORMAT" Then
            swModel.ClearSelection2 True
            Exit Function
      The above code works fine when user selects a separate sketch line
      but when user selects line that is part of block then what should be written
      If swselmgr.GetSelectedObjectType(1) = 114 Then
