Hello Guys,
I am doing an simulation on a surface model. every thig is good. but after applying thickness to the surface model, mass varies slightly from the actual solid model. So my question is is there any way through which I can assign or update the mass density to get a proper result.
In ansys that is called density balance. Any one have any idea how to do that on simulation?
change the density of the material you are applying
