yes this is a good gaming card. i believe it would run
solidworkshowever it will probably be glitchy. i would trade it in
for anvidia Quadro fx. thats just me though
Considering its the same card (GPU) as the Quadro 5500 it
would beawesome with SW. But to do so youd need to firmware
hack itto the Quadro. It will work well, no multiple windows
openbut would work ok.
Its the drivers that limit the performance not the
hardware.
Originally posted by:
Kurt VanLente Consideringits the same card (GPU) as the
Quadro 5500 it would be awesome withSW. But to do so youd
need to firmware hack it to the Quadro. It will work well, no
multiple windows open but would workok. Its the drivers that limit
the performance not thehardware.
this is true however the only problem with this is that you
wouldvoid any warranty you had with your video card by hacking
thefirmware software regardless if the software was written by
thesame manufacturer. the card was not made to be a
quadrohence the name GeForce 8800GTX.
from page 4 it states: "
six memory partitions exist on a GeForce 8800 GTX GPU. Each of
these provides a 64-bit interface to memory, yielding a 384-bit
combined interface width."
Lin Shaodun Anyone knows whythe RAM is 768MB but not
512MB or 1024MB? and the bus is not 256bitor 512Bit but at
384bit?
More information can be found on the8800GTX/GTS at:
http://tomshardware.co.uk/2006/11/08/geforce_8800_ukfrom
page 4 it states: "
six memory partitions exist on aGeForce 8800 GTX GPU. Each of
these provides a 64-bit interface tomemory, yielding a 384-bit
combined interface width." Notsure why it has 768MB GDDR3
though!
Memory would have to be an integer multiple of
384-bit... in this case 2.....
I'm using the 8800 GTS at home on personal projects and
completely amazed by the card. I know it's not an Open_GL certified
card but it sure does well. I have opened large assemblies with
lots of features without any lag or problems that I can see. This
is a good card if you want to be able to run Solidworks and then
switch over to some intense gaming in the same seating.
Jason Capriotti How much isthe card? Does Realview work
with it?
It will not give Realview, and it is not posible
to"firmware"-hack this one to a Quadro FX, as far as I
canunderstand. It seems like Nvidia have made some
hardwaredifferences between the two.
Price is about 15-25% of equal ~ Quad FX 4600.
Its the drivers that limit the performance not the hardware.
this is true however the only problem with this is that you wouldvoid any warranty you had with your video card by hacking thefirmware software regardless if the software was written by thesame manufacturer. the card was not made to be a quadrohence the name GeForce 8800GTX.
from page 4 it states: " six memory partitions exist on a GeForce 8800 GTX GPU. Each of these provides a 64-bit interface to memory, yielding a 384-bit combined interface width."
Not sure why it has 768MB GDDR3 though!
Memory would have to be an integer multiple of 384-bit... in this case 2.....
384x2 = 768
AMD Athlon 3400+
1.5 G DDR2 Ram
8800GTS 320mb
Does Realview work with it?
It will not give Realview, and it is not posible to"firmware"-hack this one to a Quadro FX, as far as I canunderstand. It seems like Nvidia have made some hardwaredifferences between the two.
