8 Replies Latest reply on Oct 28, 2014 2:56 PM by Jacob Corder
    Find if note is attached to dimension
    Neil Sommerville
      I am adding inspection notes that are attached to dimensions on my drawing.  They are simply a number or letter, one or two charaters long with a boarder around it like a dimond or other shape.  They are vary similar to a balloon.    They are attached so that when I move the dimension the note moves along with it.
      I can find and loop each dimension or note in a drawing using ".GetFirstNote" or ".GetDisplayDimensions".    However I cannot find away to detemined if the note is attached to the dimension or vise versa.   Or at least I am not undertanding it.  I have looked at ".GetAttached" and ".GetLinked" but it is not getting me anywhere.
      Surely there is a way to determine if a dimension has a note attached to it, or if a note is attached to a dimension.
      Thanks for the help.
        • Re: Find if note is attached to dimension
          Artem Taturevych
          You can try this method: Annotation::GetAttachedEntities3. But as stated in the remarks you may run into a limitation. You should use INote::GetAnnotation or IDisplayDimension::GetAnnotation to get the IAnnotation from those interfaces.
            Neil Sommerville
            I sent a request in to Solidworks and this the response.
            "I can find the APIs CreateGroup, RemoveGroups, and RemoveItemsFromGroup, but I don’t see any interface at a higher level which enables you to query what’s in a group and to change or manage it. The way this is usually handled for features in SolidWorks is through “Feature data” interface objects, but there doesn’t exist such a thing for Annotation Groups.
            It looks like what you’re running into is the long-standing enhancement request, SPR 255800 (“Would like API for Annotation Group”), part of which states: “…would like an API to query and modify an Annotation Group…”. This has been requested by a few people previously; what I’ll do is reference it in this Service Request, to indicate that another request for this has been made.
            As for alternatives, the only one I can think of for now is to use Sketch Blocks, but that might be a more cumbersome mechanism than you need, or want to deal with."
            Bummer, but I appreciate the quick response from Solidworks API Support.
              Jacob Corder
              you will need to cross Compare all Notes and Annotations in a view
              Annotation is the comon item here between DisplayDimensions and Notes.
              Dim ISwapp As SldWorks
              Dim ViewAnnotations as object = IView.GetAnnotations.
              Dim ViewNotes as Object = iview.GetNotes
              For Each ViewAnn as Annotation in ViewAnnotations
                  Select Case ViewAnn.GetType
                        Case SwAnnotationType_e.swDisplayDimension
                                For Each VNote as Note in ViewNotes
                                            Dim NoteAnn as annotation = vnote.GetAnnotation
                                          ' Use either
                                            If ISwapp.IsSame(ViewAnn,NoteAnn) = SwObjectEquality_e.SwObjectSame then
                                                'You Have Found the Annotation For This Note.
                                                  Dim ThisDim as displaydimension = noteAnn.GetSpecificAnnotation
                                                  'Here is Your DisplayDimension Object. To Get Dimension call .GetDimension2(0) 'if chamfer See Api.
                                            End if
                                            or
                                            if ViewAnn is NoteAnn then
                                            end if
                                  Loop
                  End Select
              Loop
              the code may not be 100% right. I just typed it in here. i have not tried it.
