Hi ,
I need help regarding the DimXpert auto tolerancing.
I have created a part and fully defined all features. I used Dimxpert inorder give Geometric tolerances.
My part was fully defined under Auto tolerancing , but there was no dimension information for hole pattern which I used.
Could any one help me why this is happening ? Attached cad file for reference.
Note: In tolerance method I only want to use Geometric tolerance type and not Plus- minus,
Thanks in advance.
Manmohan,
Since the holes are controlled by a FCF, their positions are managed by the Pos Tolernace. There is a setting in DimXpert Document Properties that allows you to add BASIC dimensions. When you use auto dimension, this setting must be turned on to add BASIC dims. It's at Tools>Options>Document Properties>DimXpert>Geometric Tolernace>Basic Dimensions.
Result example:
