1 Reply Latest reply on Jan 3, 2014 6:51 PM by Yong Ning
    How to use WidthFactor in TableAnnotation
    Yong Ning
      Sub replSwAnn()
        Dim rr, Str
        Dim SwDraw As DrawingDoc, swDrawExt As SldWorks.ModelDocExtension
        Dim SwSelMgr As SldWorks.SelectionMgr  ''
        Dim swTable As SldWorks.TableAnnotation
        Dim SwAnn As Annotation
        Dim SwTextFormat As TextFormat
        Set SwDraw = Application.SldWorks.ActiveDoc
        Set swDrawExt = SwDraw.Extension
        Set SwSelMgr = SwDraw.SelectionManager
        ' Select general table feature in FeatureManager design tree
        Set swTable = SwSelMgr.GetSelectedObject6(1, 0)
        With swTable
           Set SwAnn = .GetAnnotation
        End With
        Set SwTextFormat = SwAnn.GetTextFormat(0)'' SwTextFormat Result is Nothing
        With SwTextFormat
           .WidthFactor = 0.9 '→ don't run WidthFactor
        End With
        • Re: How to use WidthFactor in TableAnnotation
          Yong Ning
          Select Note result is True
          Sub tSwAnn()
            Dim rr, Str
            Dim SwNote As Note
            Set SwNote = SwSelMgr.GetSelectedObject6(1, 0)
            Set SwAnn = SwNote.GetAnnotation
            Debug.Print SwAnn.GetTextFormatCount
            Stop
            With SwTextFormat
               .WidthFactor = 0.9
            End With
            SwAnn.SetTextFormat 0, False, SwTextFormat
          code
            Set SwTextFormat = SwAnn.GetTextFormat(0) → don't Nothing
            Debug.Print SwAnn.GetTextFormatCount → result is 1
