2 Replies Latest reply on Jan 3, 2014 10:29 PM by Dmitry Zamoshnikov
    Add-in Submenus using AddCommandItem2()
    Dmitry Zamoshnikov
      sub menu 1.pngI'm creating menu groups and sub groups.  I add two sub-menus within a group and it doesn't work correctly.  The second sub-menu has the same title as the first, even though the code clearly says otherwise.  Any suggestions how to fix this?
      Code:
                  mCommandGroup = mCommandManager.CreateCommandGroup(mCommandGroupId++, "Bulk Operations", "", "", -1);
                  mCommandGroup.Activate();   // activate the top menu
                  mCommandSubGroupAssy = mCommandManager.CreateCommandGroup(mCommandGroupId++, "Bulk Operations\\Assemblies", "", "", -1);   // commands for assemblies
                  mCommandSubGroupPart = mCommandManager.CreateCommandGroup(mCommandGroupId++, "Bulk Operations\\Parts", "", "", -1);    // commands for parts
                  mCommandSubGroupDwg = mCommandManager.CreateCommandGroup(mCommandGroupId++, "Bulk Operations\\Drawings", "", "", -1); // commands for drawings
                  // set the group to have both a menu and a toolbar
                  // you could easily add new parameters and ui items to allow
                  // the user to dynamically alter these settings
                  mCommandGroup.HasMenu = true;
                  mCommandGroup.HasToolbar = true;
                  mCommandGroup.ShowInDocumentType = documentTypes;
                  // shows up only in assemblies
                  documentTypes = (int)swDocTemplateTypes_e.swDocTemplateTypeNONE;
                  documentTypes |= (int)swDocTemplateTypes_e.swDocTemplateTypeASSEMBLY;
                  mCommandSubGroupAssy.HasMenu = true;
                  mCommandSubGroupAssy.HasToolbar = true;
                  mCommandSubGroupAssy.ShowInDocumentType = documentTypes;
                  // shows up only in parts
                  documentTypes |= (int)swDocTemplateTypes_e.swDocTemplateTypePART;
                  mCommandSubGroupPart.HasMenu = true;
                  mCommandSubGroupPart.HasToolbar = true;
                  mCommandSubGroupPart.ShowInDocumentType = documentTypes;
                  // shows up only in drawings
                  documentTypes |= (int)swDocTemplateTypes_e.swDocTemplateTypeDRAWING;
                  mCommandSubGroupDwg.HasMenu = true;
                  mCommandSubGroupDwg.HasToolbar = true;
                  mCommandSubGroupDwg.ShowInDocumentType = documentTypes;
                  // Create the menus
                  int itemType = (int)(swCommandItemType_e.swMenuItem | swCommandItemType_e.swToolbarItem);
                  int menuID = 1001;
                  mCommandSubGroupAssy.AddCommandItem2("Save all drawings to PDF",    0, "", "Save all part drawings in this assembly to PDF",    0, "SaveAllPDF_Clicked", "SaveAllPDF_Enable", menuID++, itemType);
                  mCommandSubGroupAssy.AddCommandItem2("Freeze all parts",            1, "", "Freeze all parts in this assembly",                 0, "FreezeAll_Clicked", "FreezeAll_Enable", menuID++, itemType);
                  mCommandSubGroupAssy.Activate();    // activate the assembly level menu
                  mCommandSubGroupPart.AddCommandItem2("Freeze Part",                 0, "", "Freeze part",                                       0, "Freeze_Clicked", "Freeze_Enable", menuID++, itemType);
                  mCommandSubGroupPart.Activate();    // activate the part level menu
                  mCommandSubGroupDwg.AddCommandItem2("Save drawing to PDF",          0, "", "Save drawing to PDF",                               0, "SavePDF_Clicked", "SavePDF_Enable", menuID++, itemType);
                  mCommandSubGroupDwg.Activate(); // activate the drawing level menu
