6 Replies Latest reply on Dec 30, 2013 4:21 PM by Kelef Man
    cut on curveture surface
    John Smith
      Hi
      I am trying to draw a tyre I almost finish everything, but the only problem I faced is to make the hrizontal pattern on the top of the tyre surface.
      I draw the shape and made ( project cuve on the face) then tried to cut the face, but no luck.
      any suggestions ?
      many thanks
      John
        • Re: cut on curveture surface
          Deepak Gupta
          John, it might be easy for someone to look at your files or picture of what you trying to do and finally suggest you something. Since there are more ways to skin a cat the solution might be different based on the real condition.
          Please use "advanced editor" in case you want to attach any files.Click on reply and then click "use advanced editor".
            Kelef Man
            Hei'ya John, here's a sample of one file,
            l posted this in another thread somewhere,
            well here it is again, use the roll back bar
            and edit feature to see the work flow
            hope this helps- have a good'n kelef
                John Smith
                Hi Kelef...
                Thank you for your reply.
                I changed the revolved surface with revolved boss as you did with your sample file, but still can't do the cut.
                could you please check the attached file and tell me what is exactly wrong with it ?
                manu thanks
                John
                    Kelef Man
                    Hei'ya John, try this and reset the options as required,
                    your sketch needs to be checked in the original,
                    it was self intersecting(had dangling geometry)
                        John Smith
                        hi Kelef...
                        first of all, thank you for what you have done.
                        but, could you please tell me in more details what was my mistake ?
                        Many thanks
                        John
                            Kelef Man
                            Hei John, glad to have helped dude,
                            if you go to edit your sketch for the profile cut,
                            and right click on one of the contour lines,
                            and from the menu "select chain", zoom to selection,
                            and you will see that you have what is called dangling geometry,
                            in this case specifically- self intersecting*
                            l just trimmed the obvious over-run, reposition to coincident with
                            the previous channel form- confirmed
                            and then used the model to pick the different from/to
                            so that any model changes they would update and not fail
                            due to dimensions or missing geometry
                            the feature circular pattern l used the tyre edge,
                            but any concentric element would do,
                            best tempory axis, wheel origin or if needed produce
                            an axis as required
                            hope this makes sense- have a good'n kelef
