hi again, I am having trouble running a design study because the program came up with several scenary failures warnings.....
can you tell me how can I fix that?
thanks
please be more specific about the errors are
can you post the model?
have you tested a simple part to make sure your process is correcT?
if you run the simulation manually, does it solve?
the model, actually, is very simple :
the error is just " scenary failure" for the next values: 0.5; 2 ; 2.5; 2.6
yes, the simulation runs manually
I think I will run a simulation for each "missing" value
"I think I will run a simulation for each "missing" value"
"yes, the simulation runs manually"
don't jive together but it is very possible the ones that are greyed out fail
I was wrong Jared, the mesh failed for those sceneries
makes sense. glad you figured it out.
