3 Replies Latest reply on Dec 24, 2013 11:03 AM by Mohammed Elkalakhi
    Type of selected origin point
    Mohammed Elkalakhi
      Hello everybody,
      I select the origin point of an assembly,
      I get the selected object,
      But I can't determine the type of this selected object
      I tried SketchPoint but it seem that it is not,
      Can any body tell me what is the type of selected origin point ?
        • Re: Type of selected origin point
          Robert D.
          Can you upload the file here so we can see what your talking about?
            Wayne Matus
            If you record a macro, it is "EXTSKETCHPOINT".
              Mohammed Elkalakhi
              In fact I have a selection box with a filter :
              Dim filters(filtreCount) As swSelectType_e
              filters(index) = swSelectType_e.swSelEXTSKETCHSEGS
              filters(index + 1) = swSelectType_e.swSelEDGES
              filters(index + 2) = swSelectType_e.swSelDATUMAXES
              filters(index + 3) = swSelectType_e.swSelSKETCHES
              selectionBox.SetSelectionFilters(filters)
              When I select the origin point,
              In the OnSubmitSelection event I noted that the selType is swSelectType_e.swSelSKETCHES
              So I wanted to get the selected object and test if it'is an origin point,
              And I did this
              Public Function OnSubmitSelection(ByVal Id As Integer, ByVal selection As Object, ByVal selType As Integer, ByRef itemText As String) As Boolean Implements SolidWorks.Interop.swpublished.IPropertyManagerPage2Handler9.OnSubmitSelection
                      Dim isOriginPoint As Boolean
                      OnSubmitSelection = True
                      isOriginPoint = TypeOf selection Is Feature AndAlso "OriginProfileFeature" = selection.GetTypeName()
                      If isOriginPoint Then OnSubmitSelection = False
              End Function
              Thank you very much
