2 Replies Latest reply on Dec 24, 2013 4:10 AM by Shar Fa
    A springy question
    Shar Fa
      Hi guys,
      I want to creat a compression spring when the last coil has a larger diameter all the way & closed but not ground, the second to last coil changes its diameter gradually to the one of the last coil, and the first coil is closed & not ground.
      I am very familiar with creating springs in general using helix and sweep.
      When I say last coil diameter is 40mm, I want to make the seconds to last coil change gradualy from 30mm to 40mm and than the last one which is also "closed" would be 40mm all the way
