I have a "send mail" action for one of my transitions in a workflow. Our system is setup to deliver these through the email system. The issue is that some of the buttons that are auto-generated are not functional. The email has the output shown in image #1.
Did some research and found the table with the templates for this message - copied it into html and viewed and found the buttons are available (image #2).
Does anyone know if there is a simple fix for this - most likely some security setting in the mail client or server? The html code is a form submittal.
I can always adjust the template to include html links (these come through fine), but I didn't want to mess with this in case it impacted something else.
Just looking for the simplest solution.
Jake
Jake,
Try applying the fix in S-018086, seems like a slightly different issue but it may fix these for you if you haven't already updated to 2014.
