Hi guys, I have a macro that divide a spline in a number of points (100 in my macro). But there is a problem: my macro creates these points OUTSIDE the sketch. I need instead that my macro creates points INSIDE MY SKETCH.
The code of my macro is:
Option Explicit
Dim vFeatArr As Variant
Dim swFeatMgr As SldWorks.FeatureManager
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSpline As SldWorks.SketchSpline
Dim swFeat As SldWorks.Feature
Dim myRefPlane As SldWorks.RefPlane
Dim boolstatus As Boolean
Dim i As Long
Set swModel = swApp.ActiveDoc
Set swFeatMgr = swModel.FeatureManager
Set swModelDocExt = swModel.Extension
If Not swSelMgr.GetSelectedObjectType3(1, -1) = swSelSKETCHSEGS Then
MsgBox "select spline"
Exit Sub
Dim Spline As Object
Set Spline = swSelMgr.GetSelectedObject6(1, -1)
vFeatArr = swFeatMgr.InsertReferencePoint(swRefPointAlongCurve, swRefPointAlongCurveEvenlyDistributed, 0#, 100)
May you help me?
I post the orginal macro too.
Thanks a lot
