4 Replies Latest reply on Jan 2, 2014 12:06 PM by David Watkins
    InsertBomTable3 toplevelonly not setting config
    David Watkins
      I am writing a macro based on the ""Insert and Show BOM Table in Assembly" help example that inserts a BOM into an assembly then saves it out. The code works for the swBomType_Indented and swBomType_PartsOnly enumerations but with swBomType_TopLevelOnly the configuration is set to nothing even though I am setting it.  Anyone know what i am missing?
      David
      Dim swBOMAnnotation As SldWorks.BomTableAnnotation
      Dim swBOMTable As SldWorks.BomTableAnnotation
      Dim swTable As SldWorks.TableAnnotation
      Dim swAnn As SldWorks.Annotation
      Dim activeCofig As String
      Dim TemplateName As String
      Dim BomType As Long
      Dim Configuration As String
      Const OutputPath As String = "C:\temp\"
          Set swModel = swApp.ActiveDoc
          TemplateName = "P:\SolidWorks\Templates\B-D_BOM.sldbomtbt"
          BomType = swBomType_TopLevelOnly
          Configuration = swApp.GetActiveConfigurationName(swModel.GetPathName)
          Set swBOMAnnotation = swModel.Extension.InsertBomTable3(TemplateName, 0, 1, BomType, Configuration, False, swNumberingType_Detailed, True)
          Set swTable = swBOMAnnotation
          swTable.SaveAsText OutputPath & swModel.GetTitle & " BOM" & ".xls", "|"
          Set swAnn = swTable.GetAnnotation
          swAnn.Select3 False, Nothing
          swModel.EditDelete
