Since installing SW2007 I've seen several occasions where my
sketchturns black - as in a fully defined sketch - when in fact
thesketch is not fully defined. I've never seen this problem
onearlier versions. Any ideas?
We have seen this in the past when Sketch Patterns were used
in the sketch.
One way we have tracked down under defined sketches that were black
was going into the sketch, Display\Delete Relations, and arrowing
down through the list of relations while watching the Entities
Status. See attached picture.
Ok, so I figured out how to do the above, however every
relation showed that it was fully defined, yet my sketch is still
showing that it is under defined. is there another way of tracking
down where it might be under defined?
Or you can post some example here?
