I am using solidworks 2012, and want to create a motion studies of a a assembly. The motion study is very simple I am using animation wizard to set it up and rotate, explode, and implode the model. Once I render the model it is always off center. I know how to manually adjust the model. But to do this and make sure it is centered takes about 4 or 5 renders to get it in the ball park, not dead on center. I am using a aspect ratior of for true HDTV. Now I know how to manually adjust the the model to render, but there has to be a easy way to simply say you want the model in the exact center of the render, to take all of the guess work out of it. Thanks for your help.
Do you have your view sketch button selected?
