15 Replies Latest reply on May 30, 2014 4:09 AM by Paul Jones
    2014 lockup!
    Jeff Hamilton
      I just found that if I select Messages/errors/warnings under the 2014 system options my solidworks locks up and I have to kill it manually and restart. Luckily I wasn't in the middle of anything important when I found it. Has happened every time so far...
        • Re: 2014 lockup!
          Anna Wood
          Call your VAR and see if they can reproduce what you are seeing. Then they can log a bug with SolidWorks so it can get fixed.
          Cheers,
          Anna
          • Re: 2014 lockup!
            John Burrill
            Jeff, I noticed that SolidWorks took a while to populate that list of messages during which the machine was hung, but it eventually it started responding again.
            I'm noting to some pretty heavey RAM usage, so the delay might be attributable to my AntiVirus software.  I'm checking into that now.
            I'm running 2014 SP1.0 on Win 7 Pro 64bit.
            • Re: 2014 lockup!
              Dale Slotman
              Jeff,
              We've got a few guys here that have had that same issue.  If anyone finds a fix, please post!  I will do the same.
              Thanks!
              Dale
              • Re: 2014 lockup!
                Keith Parker
                Hi Jeff - just tried it on 2014 SP2.0 Win7 x64 and no hang problem.  Turned on a few 'off' messages and still ok.  I did it with & without a model file loaded just in case...
                • Re: 2014 lockup!
                  Mike Brainard
                  I had the same problem even after upgrading to SP2. I deleted the HKCU\Software\Solidworks\SolidWorks 2014 entry and let 14 rebuild it. It's working correctly now!
                    • Re: 2014 lockup!
                      Robert Tupa
                      More specifically, I renamed
                      HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2014\General\DontAskAgainOptions
                      and reopened SolidWorks.  This fixed the problem for me.
                        • Re: 2014 lockup!
                          Robert Tupa
                          The problem is back.
                            • Re: 2014 lockup!
                              John Sweeney
                              Hi Robert,
                              Can you tell me how long you let SolidWorks go before killing it?  Also, can you look into the registry key you give above and tell me thelist of messages that are shown in here?  This may help us reproduce the problem.
                              John
                                • Re: 2014 lockup!
                                  Robert Tupa
                                  John,
                                  I left it for about 10 minutes before killing it.  I was going to attach a .txt version of the registry location.  But, for some reason, the HTML editor only allows pictures and video.  So, here's the cut-and-paste version:
                                  Key Name:          HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2014\General\DontAskAgainOptions
                                  Class Name:        <NO CLASS>
                                  Last Write Time:   4/23/2014 - 9:51 AM
                                  Value 0
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 1
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 2
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 3
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 4
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 5
                                    Type:            REG_DWORD
                                    Data:            0x6
                                  Value 6
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 7
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 8
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 9
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 10
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 11
                                    Type:            REG_DWORD
                                    Data:            0x6
                                  Value 12
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 13
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 14
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 15
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 16
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 17
                                    Name:            1:1 Scale Output Warning
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 18
                                    Name:            High Quality DWG Export Warning
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 19
                                    Name:            Export hidden layers Warning
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 20
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 21
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 22
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 23
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 24
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 25
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 26
                                    Type:            REG_DWORD
                                    Data:            0x7
                                  Value 27
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 28
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 29
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 30
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 31
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 32
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 33
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 34
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 35
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 36
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 37
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 38
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 39
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 40
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 41
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 42
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 43
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 44
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 45
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 46
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 47
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 48
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 49
                                    Type:            REG_DWORD
                                    Data:            0x7
                                  Value 50
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 51
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 52
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 53
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 54
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 55
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 56
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 57
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 58
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 59
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 60
                                    Type:            REG_DWORD
                                    Data:            0x6
                                  Value 61
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 62
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 63
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 64
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 65
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 66
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 67
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 68
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 69
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 70
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 71
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 72
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 73
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 74
                                    Type:            REG_DWORD
                                    Data:            0x6
                                  Value 75
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 76
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 77
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 78
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 79
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 80
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 81
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 82
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 83
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 84
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 85
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 86
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 87
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 88
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 89
                                    Type:            REG_DWORD
                                    Data:            0x69
                                  Value 90
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 91
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 92
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 93
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 94
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 95
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 96
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 97
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 98
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 99
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 100
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 101
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 102
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 103
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 104
                                    Type:            REG_DWORD
                                    Data:            0x7
                                  Value 105
                                    Type:            REG_DWORD
                                    Data:            0x7
                                  Value 106
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 107
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 108
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 109
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 110
                                    Type:            REG_DWORD
                                    Data:            0x6
                                  Value 111
                                    Type:            REG_DWORD
                                    Data:            0x6
                                  Value 112
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 113
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 114
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 115
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 116
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 117
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 118
                                    Type:            REG_DWORD
                                    Data:            0x7
                                  Value 119
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 120
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 121
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 122
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 123
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 124
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 125
                                    Type:            REG_DWORD
                                    Data:            0x1
                                  Value 126
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 127
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 128
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 129
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 130
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 131
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 132
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 133
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 134
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 135
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 136
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 137
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 138
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 139
                                    Type:            REG_DWORD
                                    Data:            0x6
                                  Value 140
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 141
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 142
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 143
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 144
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 145
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 146
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 147
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 148
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 149
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 150
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 151
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 152
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 153
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 154
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 155
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 156
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 157
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                  Value 158
                                    Type:            REG_DWORD
                                    Data:            0xffffffff
                                    • Re: 2014 lockup!
                                      John Sweeney
                                      Hi Robert,
                                      I wasn't able to import it into my registry with the format above.  Can you do it again by exporting the reg folder you give above to a .reg file and then open the .reg file in notepad and simply cut and paste that text into your forum post?  It should look something like this with roughly 150 entries:
                                      [HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2014\General\DontAskAgainOptions]
                                      "MSG_NEEDS_UPDATE_ON_OPEN"=dword:ffffffff
                                      "MSG_LDR_EXPVIEW_SNAPSHOT_WARN"=dword:ffffffff
                                      "MSG_FILE_CONVERTED3"=dword:ffffffff
                                      "IDS_WARN_GENERAL_WINXP_EOL"=dword:ffffffff
                                      "IDS_2006_LW_NEEDS_CONVERSION"=dword:ffffffff
                                      "IDS_WARN_GENERAL_VISTA_EOL"=dword:ffffffff
                                      "IDS_WARN_GENERAL_32BIT_EOL"=dword:ffffffff
                                      John
                                        • Re: 2014 lockup!
                                          Robert Tupa
                                          Windows Registry Editor Version 5.00
                                          "MSG_LDR_INFO"=dword:ffffffff
                                          "MSG_FILE_CONVERTED3"=dword:00000006
                                          "MSG_DISPLAY_RECENT_DOC_OVERLAY"=dword:ffffffff
                                          "MSG_NEEDS_UPDATE_ON_OPEN"=dword:00000001
                                          "MSG_LOAD_EXTERNAL_DOC"=dword:ffffffff
                                          "MSG_LOAD_LW_COMPS_OPTIONAL"=dword:00000001
                                          "MSG_SHOW_FEAT_DIMS_ON_ANNVW_ACTIVATE"=dword:ffffffff
                                          "MSG_EXTERN_REFS_CHANGED2"=dword:00000006
                                          "MSG_PART_UPDATE_ERROR_ON_SAVE"=dword:00000001
                                          "IDC_GENERAL_WARN_SKETCHING_IN_ASSEMBLY_CONTEXT"=dword:ffffffff
                                          "MSG_LINKED_DESIGN_TABLE"=dword:ffffffff
                                          "IDS_CONTINUE_REBUILD_AFTER_ERROR"=dword:00000001
                                          "MSG_DIM_OVER_MAKE_DRIVEN"=dword:00000001
                                          "1:1 Scale Output Warning"=dword:ffffffff
                                          "High Quality DWG Export Warning"=dword:ffffffff
                                          "Export hidden layers Warning"=dword:ffffffff
                                          "MSG_EDITING_PART_NUMBER1"=dword:ffffffff
                                          "MSG_EDITING_PART_NUMBER3"=dword:ffffffff
                                          "MSG_EDITING_PART_NUMBER2"=dword:ffffffff
                                          "MSG_EXCLUDED_FROM_BOM"=dword:ffffffff
                                          "MSG_ALWAYS_DISSOLVED"=dword:ffffffff
                                          "MSG_UPDATE_ON_CHANGE_EQN_CONFIG"=dword:ffffffff
                                          "MSG_SAVE_RELOAD"=dword:00000007
                                          "IDS_UPDATE_BASE_ANG_RUN_DIM"=dword:ffffffff
                                          "MSG_UPDATE_ZERO_ORD"=dword:00000001
                                          "IDS_APPLYING_MODO_ASSET"=dword:ffffffff
                                          "MSG_MOVING_TO_TABLET_LAYOUT"=dword:ffffffff
                                          "MSG_WARN_TABLET_LAYOUT_NEED_RESTART"=dword:ffffffff
                                          "MSG_FIND_TOOLBOX_IN_EPDMVAULT"=dword:ffffffff
                                          "MSG_WARN_TEMPLATES_NOT_LOADED"=dword:ffffffff
                                          "MSG_DOCUMENT_ALREADY_OPEN"=dword:00000001
                                          "MSG_EQU_MULTIPLE_REF_WARNING"=dword:ffffffff
                                          "MSG_UNUSED_EQUS_CONV_TO_COMMENTS"=dword:ffffffff
                                          "MSG_CT_START_FACE_REFERENCE_MISSING"=dword:ffffffff
                                          "MSG_CTHREAD_LENGTH_MODIFIED"=dword:ffffffff
                                          "MSG_BAD_SKPATTERNS_DELETED"=dword:ffffffff
                                          "IDS_SEVERE_BOM_LINK_READONLY"=dword:ffffffff
                                          "MSG_ERR_SHAPE_FEATURE"=dword:ffffffff
                                          "IDS_CUSTOMPROPS_VALUES_TO_DERIVED_UNITS"=dword:ffffffff
                                          "MSG_CUTLIST_PROPS_NOT_POPULATED_BROKEN_LINK"=dword:ffffffff
                                          "MSG_DRW_LW_AUTO_RESOLVE"=dword:ffffffff
                                          "MSG_CIRCULAR_REF_IN_DR_VIEW_SKETCH"=dword:ffffffff
                                          "MSG_WARN_ANIM_PW_LIGHT_CHANGES"=dword:ffffffff
                                          "MSG_WARN_BASIC_MOTION_UNSUPPORTED_CONTACTS"=dword:ffffffff
                                          "MSG_LINKED_FT_CHANGED"=dword:ffffffff
                                          "MSG_EXT_DOC_REF_NOTFOUND"=dword:00000007
                                          "IDS_SNAPSHOT_WARNING_TITLE"=dword:ffffffff
                                          "MSG_WARN_EDIT_CONVERTED"=dword:00000001
                                          "MSG_FORM_TOOL_PRESENT"=dword:ffffffff
                                          "MSG_UPDATE_PARENT_CUTLIST"=dword:ffffffff
                                          "MSG_LEGACY_CUTLIST_PROPS"=dword:ffffffff
                                          "MSG_UPDATE_CUTLIST"=dword:ffffffff
                                          "MSG_UPDATE_PARENT_CUTLIST_FOLDER"=dword:ffffffff
                                          "MSG_CANNOT_ADD_PROP_TO_SUBWELD"=dword:ffffffff
                                          "MSG_REMOVE_EQUATION_MEASURE"=dword:ffffffff
                                          "MSG_EDITPART_LOCKED_EXTERNAL_CONTXT"=dword:ffffffff
                                          "MSG_UPDATE_LINKED_OLE_ITEMS"=dword:00000006
                                          "IDS_MSG_WARN_SAVE_CONFIGS"=dword:ffffffff
                                          "MSG_WARN_SAVE_VIRTUAL_COMP"=dword:00000001
                                          "MSG_FILE_READ_ONLY"=dword:ffffffff
                                          "MSG_DESIGN_TABLE_EMPTY"=dword:ffffffff
                                          "MSG_ALPHA_RELATIONS_WARNING"=dword:ffffffff
                                          "MSG_SELECTIVE_OPEN_INFO"=dword:ffffffff
                                          "MSG_DO_NO_LOAD_HIDDEN_COMPS_INFO"=dword:ffffffff
                                          "MSG_OPEN_SUMMARY_DIALOG"=dword:ffffffff
                                          "MSG_EXT_EQN_REF_NOTFOUND"=dword:ffffffff
                                          "MSG_WARN_EDIT_READ_ONLY"=dword:ffffffff
                                          "MSG_NEEDS_UPDATE_FOR_SENSOR"=dword:ffffffff
                                          "IDS_EDRW_WARNING_SAVE_ANIMATION"=dword:ffffffff
                                          "MSG_INFERRED_RELS_OVERDEFINE"=dword:ffffffff
                                          "MSG_EXIT_SKETCH"=dword:00000006
                                          "MSG_MEASURE_ACCURACY"=dword:ffffffff
                                          "MSG_GRAPHICS_SECTION_MEASURE_ACCURACY"=dword:ffffffff
                                          "MSG_SPEEDPAK_OBSOLETE"=dword:ffffffff
                                          "MSG_WARN_MAKE_VIRTUAL_COMP"=dword:ffffffff
                                          "MSG_WARN_ONLY_TOP_LEVEL_COMP_MAKE_VIRTUAL_COMP"=dword:ffffffff
                                          "MSG_TOOL_BOX_COMPONENT_NOT_ALLOWED_MAKE_VIRTUAL_COMP"=dword:ffffffff
                                          "MSG_FAIL_TO_SAVE_VIRTUAL_COMP_EXTERNAL"=dword:ffffffff
                                          "MSG_UPDATE_ALL_CONFIGS_FEAT_LOCK"=dword:ffffffff
                                          "IDS_WARNING_UNABSORBED2_TITLE"=dword:ffffffff
                                          "MSG_UO_CONFIGTAB_NEGDIMS"=dword:ffffffff
                                          "MSG_IGNORETOL_FORLIMITMATES"=dword:ffffffff
                                          "IDS_DISABLE_DESIGN_TALBE_VALIDATION"=dword:ffffffff
                                          "IDS_DELTE_PARENT_SM_FEAT"=dword:ffffffff
                                          "MSG_COSMETIC_WELD_DRAG_DROP"=dword:ffffffff
                                          "MSG_CONFIRM_DELETE"=dword:00000069
                                          "MSG_CONFIRM_DELETE_DESIGNTABLE"=dword:ffffffff
                                          "MSG_CONFIRM_DELETE_SKETCH_ITEM"=dword:ffffffff
                                          "IDS_VISTA_EXT_DOC_REF_MISMATCH_TITLE"=dword:ffffffff
                                          "IDS_VISTA_EXT_DOC_REF_MISMATCH2_TITLE"=dword:ffffffff
                                          "IDS_VISTA_SAVE_AS_WARNING_TITLE"=dword:ffffffff
                                          "MSG_ASSEM_NOT_SAVED_WHEN_SAVE_VIRTUAL"=dword:ffffffff
                                          "MSG_CHOOSE_DISPLAY_STATE"=dword:ffffffff
                                          "IDS_PROMPT_FOR_OLD_PW2"=dword:ffffffff
                                          "MSG_CREATE_GLOBAL_VARIABLE"=dword:ffffffff
                                          "MSG_DELETE_REVISION_TABLE_ROW"=dword:ffffffff
                                          "IDS_DELINKING_BOM"=dword:ffffffff
                                          "MSG_TBL_CELL_LINK_BROKEN"=dword:ffffffff
                                          "MSG_SAME_PARTNUM_DIFF_CONFIG"=dword:ffffffff
                                          "MSG_DIM_REMOVE_RELATIONSHIP"=dword:ffffffff
                                          "MSG_DELETE_REVISION_TABLE_NOTE"=dword:00000007
                                          "MSG_DELETE_CORRESPONDING_REVISION_SYMBOLS"=dword:00000007
                                          "MSG_WELD_TABLE_BREAK_LINK_SYNC"=dword:ffffffff
                                          "MSG_WELD_TABLE_BREAK_LINK_NO_SYNC"=dword:ffffffff
                                          "MSG_WELD_BEAD_HIDDENT_IN_EXPLODED_VIEW"=dword:ffffffff
                                          "MSG_WARN_MASS_COSMETIC_PATTERN"=dword:ffffffff
                                          "MSG_NEEDS_UPDATE_ON_SAVE"=dword:00000006
                                          "MSG_EXIT_SKETCH_BEFORE_SAVE_2"=dword:00000006
                                          "MSG_WARN_EXPORT_COSMETIC_PATTERN"=dword:ffffffff
                                          "MSG_CUTLIST_HAS_NO_PROPS"=dword:ffffffff
                                          "MSG_SPLIT_REATTACH_FILES"=dword:ffffffff
                                          "IDS_VERIFY_REMOVE_ALL_APPEARANCES"=dword:00000001
                                          "IDS_IGNORING_FEATURE_APPEARANCES"=dword:ffffffff
                                          "IDS_VERIFY_REMOVE_FLOOR_FOR_FLATTEN_FLOOR"=dword:ffffffff
                                          "IDS_HEALING_WANNA_DO_IT"=dword:00000007
                                          "MSG_MOVECOPY_BODY_ZERO_TRANS_CONFIRM"=dword:ffffffff
                                          "MSG_FT_CONFIG_CHANGED"=dword:ffffffff
                                          "MSG_WARN_MOVE_VIRTUAL_COMP"=dword:ffffffff
                                          "MSG_RECREATE_MATES_AFTER_DISSOLVE_MIRROR_COMP"=dword:ffffffff
                                          "MSG_WARN_COPY_VIRTUAL_COMP"=dword:ffffffff
                                          "MSG_EXIT_SKETCH_BEFORE_SAVE"=dword:ffffffff
                                          "ID_ASK_REBUILD_ASSEMBLY"=dword:00000001
                                          "MSG_EDITPART_NOT_POSITIONED"=dword:ffffffff
                                          "MSG_SELECTIVE_OPEN_CONVERSION"=dword:ffffffff
                                          "MSG_LOCK_ROTATION_ABOUT_MATE_AXIS"=dword:ffffffff
                                          "MSG_LAV_OPEN_CONVERSION"=dword:ffffffff
                                          "MSG_LAV_FOUND_INACTIVE_CONFIG"=dword:ffffffff
                                          "MSG_LAV_PART_WAS_REGENED"=dword:ffffffff
                                          "MSG_LAV_PART_WAS_MISSING"=dword:ffffffff
                                          "MSG_LAV_NO_TESS_UPDATE"=dword:ffffffff
                                          "MSG_WARN_PHYSICAL_SYM_NO_MOTION_OBJECTS"=dword:ffffffff
                                          "MSG_ADJUST_ANIM_FRAME_RATES"=dword:ffffffff
                                          "MSG_RECALCULATE_FOR_AVI"=dword:ffffffff
                                          "MSG_PATH_MATE_IN_MOTION"=dword:ffffffff
                                          "MSG_OPT_CUR_SCENARIO_RESULTS_ARE_INTERPOLATED"=dword:ffffffff
                                          "MSG_RESOLVE_LW_FOR_CUSTOM_PROPS"=dword:00000006
                                          "MSG_LOAD_DRWSHEET_FOR_CUSTOM_PROPS"=dword:ffffffff
                                          "MSG_CONFIG_ALLPARMETER"=dword:ffffffff
                                          "MSG_CONFIRM_TRIM_DEP_DIMS"=dword:ffffffff
                                          "MSG_VIRTUAL_COMP_NEED_SAVE"=dword:ffffffff
                                          "MSG_WANT_PROJECTED_DIMS_MULTIPLE_VIEWS"=dword:ffffffff
                                          "MSG_ASK_SECTION_TYPE_PRESELECT"=dword:ffffffff
                                          "IDS_CONVERT_VIEW_TO_SKETCH_WARNING_OK"=dword:ffffffff
                                          "IDS_BREAKING_BOM_LINK"=dword:ffffffff
                                          "MSG_WALKTHROUGH_BAD_SKETCH"=dword:ffffffff
                                          "MSG_WALKTHROUGH_BAD_SELECTIONS"=dword:ffffffff
                                          "MSG_WALKTHROUGH_CAPTURE_INTRO"=dword:ffffffff
                                          "MSG_WALKTHROUGH_WARN_WALLS"=dword:ffffffff
                                          "MSG_SAVEAS_REFWARNING"=dword:ffffffff
                                          "IDS_SEVERE_BOM_LINK_DETACHED"=dword:ffffffff
                                          "MSG_WARN_ABOUT_LONG_TIME"=dword:ffffffff
                                          "IDS_DIMPATTERN_DISABLE_PREVIEW"=dword:ffffffff
                                          "IDS_PROMPT_FOR_PERSPECTIVE"=dword:ffffffff
                                          "MSG_PV_NW_RENDER_SPLASH"=dword:ffffffff
                                            • Re: 2014 lockup!
                                              John Sweeney
                                              Hi Robert,
                                              Good news.  With your registry I am able to reproduce the hang.  This issue has been given SPR number 783857 and we will begin working on a fix.  Once we figure out why your registry values cause a hang while most others do not, we will also try to give you a workaround for the problem.
                                              Thanks for your input,
                                              John
                                • Re: 2014 lockup!
                                  Bryan Nathan
                                  Has there been any progress on this? I need to fix when an error message shows, but cannot access that screen because it locks up my computer.
                                    • Re: 2014 lockup!
                                      Patrick O'Hern
                                      You can try hitting the "Reset" button in your System Options and then manually redo all of your settings.  Using Copy Settings Wizard to reimport your settings will cause the error to happen again.
                                      After manually readjusting your settings, you can save a Copy Settings Wizard file that will not cause this error anymore.
                                    • Re: 2014 lockup!
                                      Paul Jones
                                      Please be warned though, the next time you click on the Message/Errors/Warnings after the reset it's fine; subsequent clicks will result in the lock up again.  Warning you all as it's just happened to me again and lots of work has been lost
