Looking on sugestions on converting this file to sheet metal to unfold and laser cut? Not sure is this is a good part for lofted bends, dont have a lot of experience with lofts?
Thanks and happy holidays! Chris
you won't be able to convert the existing baffle but if you start with a new part you can add sheetmetal feature.
after which i would use the unfold feature to add the holes (while part was flat).
i left it as a single piece but you could easily split into two.
see attached
