Creating .dxf from imported STEP
Question asked by Neil MacDonald on Dec 18, 2013
Latest reply on Jan 7, 2014 by Jerry Steiger
Hi all,
I am trying to generate blocks for use in Draftsight, from an imported STEP file. The original assembly was created on 2013 and I am using 2010, so the assembly was supplied in STEP.
When I import the part into solidworks, it has a number of surface faults and gaps that will not heal.
I have tried creating a drawing and saving as .dxf and this only gives a few of the pieces of the assembly, not the full thing. When the view has the shaded surfaces selected, it displays as the assembly should, just not in wireframe.
I have saved the assembly as a .sldprt, same result.
I have tried saving as .dxf and with the same result.
Are these issues relating to the unhealed surfaces and gaps? Are there alternative methods of generating the blocks I need?
Cheers,
Neil MacDonald
