3 Replies Latest reply on Jul 19, 2015 11:44 PM by Jerimiah Welch
    How to run Solidworks API code written on different Machine
    Abhishek Lad
      I had written code which run on my machine(64bit Win7) successfully, but when i run it on
      other machine(32bit winXP) its shows following error.
      the showing for line
      SwApp=Getobject(,"Sldwork.Application")
      System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'SolidWorks.Interop.sldworks.SldWorks'.
      This operation failed because the QueryInterface call on the COM component for the interface with IID '{83A33D22-27C5-11CE-BFD4-00400513BB57}' failed due to the following error:
      No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
      my machine is 64bit and other is 32bit is that problem
      but i had try same code on 32bit windows7 is works Successfully. i want to run it on winXP-
      32bit.
