Is there an opiton when saving an assembly as parasolidworks that will save each individual part a separate body?
basically I want to import that parasolidworks assembly in a normal solidworks assembly and mate the imported bodies and have interact and move
OK, let's clarify a little. There is no such thing as a "parasolidworks" assy. Do you have a SolidWorks assy or a parasolid assy?
Are you wanting to ...
1) Export (save as) a SolidWorks assy to a parasolid format
or
2) Import (open) a parasolid assy and convert it to a SolidWorks assy
or
3) Insert a parasolid assy into a SolidWorks assy
I should have clarified. I have solidworks 2011 an engineer I collaborate with has 2013. He keeps sending me parasolidworks assembly but the problem is the bodies are frozen and sometimes mesh together. What I was wondering. Is there a feature that will allow him to send me parasolidworks format of the assembly but the parts being seprate bodies. So I can import this parasolidworks assembly in a normal solidworks assembly with features and have the imported bodies of the parasolidworks assembly mate and interact with one another
Once again ... there is no such thing as a "parasolidworks" assembly. It's just a parasolid format file.
Sorry, I don't know what you mean by that.
Yes. See Don Van Zile's post above ... but it will be a multibody part file. (See next comment)
After importing as a multibody part, you will be able to save the bodies as separate parts while at the same time re-creating an assy. However, the parts will not be constrined with mates. You will have to re-create the required mates or simply fix or lock the parts in place.
Also, no features will be available in the newly created parts unless you are able to use the feature recognition module (FeatureWorks).
What do you actually need to do with the parts in this assembly?
Hi Andi,
You can save an assembly as an .sldprt file (multibody part file) and export that as a parasolid file.
