This should be a very simple process.
I have a simple model and would like to print it.
I need to convert it to .stl format.
Here is what happens.
The model units are inches.
I save the model in .stl format.
I open the .stl drawing and save it as a part.
I create an assemble out of the new and the original parts.
The new part is humongous!
I delete the new files.
I open the original part, and save it as a copy and add test to the name.
I open the new test part, and change it's units to mm and save it.
I save it also save it in .stl format. I select options, and set the dimensions to mm prior to saving the file.
I open the the the .stl file and save it as a SW part.
I open the test part and create an assembly using the test part and the .stl part.
The .stl part is humongous!
What am I doing wrong?
Karl
2. Why in the world are you opening then stl format to convert back to a part?
1. Don't you already have it as a native part (*.sldprt)?
Stl format changes the geometry into thousands of faceted planar trianglular surfaces (not smooth).
Please explain why you are what sounds to me like going around in circles for no benefit?
I feel like I must be missing something in your problem description.
