Hi, i have some troble for getting coherent results in a keyseat simulation. I think this is because of the mesh.
let me show you what i mean:
standard mesh with control of 0.5mm, relation 1.2, the mesh is not even(for me)
based on curvature mesh:( i think it is a better. the thing is that i only want to focus o the end fillet, not the whole part and i can´t do it with this tipe of mesh)
minimun size of element: 0.5mm
number of circles: 36
relation: 1.2
What else can i do?
based on your previous post, i suspeect "coherent" results is likely more an aspect of your setup vs the mesh.
curvature vs standard mesher = equivalent. curvature mesher is generally better at handling bad geometry and is multithreaded for faster meshing. but otherwise pretty equivalent from an accuracy perspective.
regarding this actual problem, i don't know what the problem defintiion is or how you think it is affecting the results.
i think your question is "why can't i create a mesh control with curvature based mesher"?
and "why isn't the standard mesher more uniform"?
