Need assistance troubleshooting.
How can we troubleshoot what specifically is causing the service mentioned to consume 100% CPU?
Thanks in advance
Thanks in advance
Tim,
Use process explorer and seel what thread is taking up 100%
http://technet.microsoft.com/en-us/sysinternals/bb896653
Double click on the archiveserverservice process and go to the threads tab:
Paste a picture back if it's not obvious, also using ProcMon to capture it's activity and counting occurances can tell you if it's just doing the same thing over and over. If you capture a trace I can take a look.
I am having this same problem and can't figure it out. I have a laptop that I sometimes work from home, so we put a second vault on it that replicates the office vault "once per hour, Monday to Friday" in the schema settings.
If I turn that to "never", ArchiveServerService.exe never starts up and I can work fine. If I check something out it pulls the file down over my VPN and I can work with it and check it back in. But if I set the schema to once per hour, m-f, it will pop up in my Resource Monitor and hog somewhere between 60 and 90% of my CPU resources making the laptop unusable.
Hi Iain,
Near term, leave the the schema set to "never" and on-demand replication will pull the files down when you work with them. Long-term, remove the replicated archive server. It's not going to help you in this configuration IMHO.
One client of mine did this and experienced the same performance issue you are experiencing so I tried it on my own laptop to troubleshoot. Same thing, poor performance.
There is really too much going on with your laptop to act as both a replicated archive server AND anything else you use the laptop for. Besides, the server really "should" be running on a server with a server operating system to behave as designed. Plus, I am not sure your VAR or SW will "support" this setup.
Hope this helps,
Tim
Thanks for the feedback, I appreciate it. I turned the schema to "Never" and you're right, it just seems to work "on demand" now which is just fine for what I am using it for.
I don't like offline mode because you can't add files to the vault while working offline - unless I'm doing something wrong...
Tim,
