While using SW 2012 x64, I'm trying to hide the boundary of the Detail View. Turning off the "Full Outline" check box only works for boundary edges that are not cutting the part (See Detail C). I tried using a Layer, not working.
Well, there is this solution: https://forum.solidworks.com/message/142153#142153 I haven't tried this in awhile. I don't remember if it applies to the portion of the circle that cuts across geometry.
Thanks, but this only seems to be possible in older versions of SW. The Line Font dialog doesn't have a Detail Circle selection.
OK, I got it to work, but then all Detail View borders are off. Even selecting "Full Outline". Then I tried the Layer option, but there aren't separate Layers for Circle and Border (see PNG). Thanks for the help, but I won't be using this one.
George,
This is understandable. I was offering this as a workaround for now. There are several SPRs that are currently covering this topic from various perspectives. I invite you to goto your customer portal in the Enhancment Requests area and search for the keywords hide detail circle and vote for the ones that you feel suit your needs. This will help rise us track overall requests for this need.
Thanks!
I've been wrong here several times in the last few days, but I'm pretty sure you can't hide that.
