DLDylan Lucas06/12/2013
Hello Solidworks,
Is there a way to change export setting of multiple sheet drawings to DXF files.
For example when saving multiple sheet DXF files Solidworks outputs 00_<Filename>, 01_<Filename>, etc.
Can it output <Filename>_<Sheet Num>_<Custom Property>...?
Ideally I would like to output <Part_Num>_<Sheet_Num>_Rev<Rev>
Where Rev is text and <Rev> is the revision of the part from the sheet format.
Any Suggestions?
