I am new to Solidworks and I am trying to draw a vertical line on a Top plane.
I have figured I can't draw a vertical line because the cursor or the direction of the origin which I have made an coincident relationship to
is not facing up ( maybe the default setting)
How can i change this issue?? I want to draw a vertical line on a Top plane.
or how can i chane the direction of the origin so I CAN draw a line in a different direction?
I found out you can but i can't. Please help.
Hi Eunsu,
Use the "Modify" command under tools>sketch tools>Modify. Please check out the help file since there are lots of options to rotate, scale, mirror (flip) etc. with this command.
regards
Mark
